Topic:Crossed drilled (or dimpled) & slotted front & rear rotors (where to buy)
Mulholland 01Afternoon gentlemen... I am looking for front and rear cross drilled (dimpled) and slotted rotors. I have searched endlessley for a good brand and can't seem to find anything? I looked at EBC brakes but they only have the front and do not have an estimate on anything for the rear. I really would like to get matching but I can settle for front cross drilled (dimpled) & slotted and the rear just slotted. Any advice?? Thanks
LSKThe front rotors are steel and replacements are easily found. The rear rotors are a composite aluminum material and only work with organic brake pads. I'm not sure if anyone is making a replacement rear rotor. Using anything other than the organic pads will heat up the rear rotors too much and ruin them.
You can do a search and find many threads about the rear rotors.
This message has been edited by LSK on 06-24-2019 at 02:47 PM
Mulholland 01Gotcha.. that’s where I’m running into the problem. Anyone else care to share...
robinI have these work and look great .Ceramic pads for no dust...
http://www.buy brakes.com/plymouth-prowler-base-2001/brake-kits-rotors-and-pads/stoptech-brake-kit-best-price-budget-select-drilled-and-slotted-rotor-and-pad-kit
http://www.autozone.com/brakes-and-traction-control/performance-brake-pads-rotors-kit/power-stop-performance-brake-pads/727540_795672_0_2805
This message has been edited by robin on 06-24-2019 at 04:56 PM
Mulholland 01Thanks for the info.. Now i'm trying to locate the rears
robin http://www.moparpartsoverstock.com/p/__/ROTOR-Brake/6658639/04815750.html
part number 04815750
Rears are a special composite . don't use ceramic pads.
So far only OEM work. To much money to drill.
That last a long time if treated right.
http://www.summitracing.com/int/parts/mop-04815750/overview/year/2001/make/chrysler/model/prowler
This message has been edited by robin on 06-25-2019 at 10:00 AM
